circuit breaker
Yes I was test driven after I got my bike back together. tested it around the block at day time no problem, went to drive at night got a block away and bike shut down, coasted bike started fired up headed back to put it up and shut down again, coasted bike fired up got home. Could that be the problem?
Sounds like a short or defective circuit breaker. That it only happened at night makes me think you may have a problem with the lighting circuit. Make sure all your connections are tight and no wires are worn through. Places to check for bad wires is between the battery box and oil tank, near the clutch arm, near the neck post and fork stops, under the handlebar switch housings.
If you short out when you hit the lights, and I am assuming your lights are on the dash, get a inner tube and cut it out to fit over the connections on the key/light switch..plus check your ground, pull ita nd sand the landing spot hombre..i just enjoy the myriad of challnges old iron tossses at yaaaaaa..ruben
Aashif Smith
Audio Systems
08-20-2018 08:32 AM
jcallesano
06-01-2014 08:39 PM
