kickstart install instructions?
Old 11-25-2009, 01:30 PM
stell55chevy's Avatar
stell55chevy
stell55chevy is offline
Default kickstart install instructions?
does anyone know where I can find a 4 speed rotary top kickstart conversion / install instruction online?
I am gonna purchase a conversion kit and I want to see what is involved with the project.
thanks for any input
Old 11-25-2009, 01:59 PM
48pan's Avatar
48pan
48pan is offline
who is the manufacturer of the kit? I would start with them. Probably get it on-line at their website.
Old 11-25-2009, 02:04 PM
stell55chevy
was gonna go with the cheap Jireh kit. just trying to see if i am gonna need any special tools or anything for the job.
Old 11-25-2009, 02:06 PM
FilthyLucre's Avatar
FilthyLucre
FilthyLucre is offline
The procedure is the same as the ratchet top transmission. The bumper plate is built into the retainer plate mainshaft bearing on 80 and later models. I'm not familiar with the very late model 4 speed transmissions, 80-84. They used two different mainshafts in those years. The mainshaft for a kick starter has to be threaded at the very end on the kick start side. The 79 rotary top mainshaft is threaded. Before you order the parts check under the cover to make sure your mainshaft is threaded and it also must have a key way to hold the starter clutch gear. If not you may not be able to use one.
Old 11-25-2009, 02:21 PM
stell55chevy
i have already had the endplate off and it is threaded and it has a keyway in it.
so it is a pretty straight forward job? not too complicated?
Old 11-25-2009, 06:34 PM
FilthyLucre
Very straight forward. The starter gear mainshaft needs to slide on the mainshaft, hone it to fit if it doesn't. Depending on what crank they give you in the kit (the shaft the kick arm attaches to.) you may have to play with it to get it in the proper position. Old stock shafts had a notch on the arm end for the pinch bolt. Later cranks had a circular groove so it would accomodate the swing out kick arm also. The single notch goes at 12 o'clock. If it is in the wrong position you may not be able to wind the return spring properly. Don't forget the washer behind the spring, chamfer toward spring. The starter gear mounts to the crank with the dowl pin at 7 o"clock.
Old 11-27-2009, 08:25 AM
Pälli's Avatar
Pälli
Pälli is offline
Red face That kick start is simpe
I also repar my own.. Now all are heavy duty parts.. I have stroker engine and tigh camsaft and bored head and quite lot of pressure . Those orginal parts do not last my use.. I broke also 3 taiwain made pedals and now i have Usa made brass pedal and affect that i t last.. I do not get it broken yet.
Old 11-27-2009, 08:27 AM
Pälli's Avatar
Pälli
Pälli is offline
Red face That kick start is simple
How i can delete.? I send 2 messages.. 1 to mutch..
72_shovel
Shovelhead
22
07-09-2014 07:28 AM
skiptone
03-02-2010 07:47 AM
bearlocations
05-21-2009 09:56 AM
powaypete
Classic
03-04-2009 07:11 PM
csd4682
Ironhead
04-19-2008 06:11 AM
Quick Reply: kickstart install instructions?
