79 fxe tank lift
Old 12-26-2009, 11:30 AM
streetbob09's Avatar
streetbob09
streetbob09 is offline
Default 79 fxe tank lift
Does any body make a tank lift for a 79 fxe or do i have to make one myself
Old 12-27-2009, 11:04 AM
jeffwoods1962's Avatar
jeffwoods1962
jeffwoods1962 is offline
If your trying to get them off the rockers due to rubbing, i've actually fabricated spacers to widen them out a little to get them off the rockers.
I have seen riser kits for the back of the tanks but nothing to accomodate the front attachments.
Old 01-01-2010, 02:16 AM
fairplay's Avatar
fairplay
fairplay is offline
I am in the process of fabing one up as we speak for a flh. I added 18" bars and polished rockers and the lifted tank would show both off nicely. What a pita. I need to cut out the tank indentions and weld in flat pannels on the inner wall (the backbone runs thru the middle of the tank).
then I will have to reseal it with kreem, red kote or whatever.
why do we do this to ourselves?
Old 01-01-2010, 03:39 PM
FilthyLucre's Avatar
FilthyLucre
FilthyLucre is offline
If you have fatbobs (2 piece tanks) put spacers in the rear to move it outward away from the rockers. You can space the front also. Before you tighten the tanks down put a piece of card board between the lower front mount and the rocker box. This will keep it off the rockers when you tighten them up. Remove the cardboard after. If you have the one piece tank, it had a stock horseshoe shaped rubber mount that fit between the tank and the backbone of the frame.
Old 01-03-2010, 02:45 PM
fairplay's Avatar
fairplay
fairplay is offline
This is what I got so far. The front is lifted 4" and the rear is up 1-3/4" By drilling into the cross support on the frame and welding in a sleeve (probably not needed but what the heck, only took another 1/2 hour) I was able to lift the front. I then had to lift the back to clear the frame. All the brackets will be fully removeable to go back to stock. The only thing that can't be reversed is the hole in the frame and thats not a big deal anyway.
I think it gives it nice lines and can't wait to get the motor back.
Old 01-03-2010, 03:01 PM
fairplay's Avatar
fairplay
fairplay is offline
took me a while, this is off my phone b/c the camera pix won't load
Old 01-03-2010, 03:03 PM
fairplay's Avatar
fairplay
fairplay is offline
here's one more
Livnoutdoorsxd9
10-19-2021 10:53 AM
Bagger_Vance
01-05-2020 11:30 PM
ghoulardo
2014-2023 Touring Models
07-09-2018 05:22 AM
hutchison101
08-30-2009 02:59 AM
PhatHarley4Me
01-19-2005 09:08 PM
Quick Reply: 79 fxe tank lift
