So...how important is an oil cooler?
Old 12-16-2009, 09:49 AM
Lundee's Avatar
Lundee
Lundee is offline
Default So...how important is an oil cooler?
I've got my little 80" shovel project going and was wondering if I need to keep the factory oil cooler or if I can ditch it? Few things. I put in a 3.5 quart oil tank w/a remote mount oil filter about 18" away from the tank. I live in Northern Ut where the temp does get to 90-95 for a few months in the summer but usually about 80-85. So do you guys think I need it or can I scrap it? Thanks.
Old 12-16-2009, 11:50 AM
hiwaytime's Avatar
hiwaytime
hiwaytime is offline
On a Shovel, I would keep the oil cooler. I live in Utah also and I always ran an oil cooler on a shovel but never had any problem with the bike related to heat but they do get hot. My 76 FLH is an 82" big bore, stock stroke w/S&S barrels and pistons, I pulled into Moab on a hot day in July and felt something vibrating between my legs, I could not figure out what it was. Much to my horror, when I took off the gas cap, The gasoline was boiling in the gas tank. We went to Woodys. S&S in the day recommended Aeroshell 50W in their motors. We ran it in the trans and engine and never had a problem with either. I still use it in my Shovels to this day. I still enjoy riding Shovels but when you shift a 96" into 6th gear at 80 MPH it makes you glad to have lived this long. Enjoy your Shovelhead. Happy Trails
Old 12-16-2009, 01:46 PM
Lundee's Avatar
Lundee
Lundee is offline
Welcome to the forum hiway. Where the hell is Kenilworth? Ya my shovels just a bar hopper. I've got a night train for the long haul. Although I'm pretty excited to do some over nighters on the shovel. Thanks for the info
Old 12-16-2009, 04:35 PM
FilthyLucre's Avatar
FilthyLucre
FilthyLucre is offline
An oil cooler will make about a 20 degree difference. If you ditch it I would use a heavy weight oil in the summer. In South Florida I run 60 or 70 weight.
Old 12-21-2009, 04:56 PM
TW's Avatar
TW
TW is offline
I've used a cooler (and straight 60) on all 3 of the Shovels I've had. A lot more cast iron on those older motors.
Old 12-21-2009, 05:46 PM
Tukt0yuktok's Avatar
Tukt0yuktok
Tukt0yuktok is offline
Default The benefits of lubrication...
I have always used an oil cooler, especially on my shovels. Like another favorite thing in my life, I find if both are well and truly lubricated, the ride is much longer and trouble-free. Oil is the cheapest investment you can make to keep your ride around for decades and decades, rather than just a few years.
Tuk
Old 12-25-2009, 01:14 PM
hotrod351's Avatar
hotrod351
hotrod351 is offline
go with a cooler. if you worry your running to ccole you can always buy a oil cooler thermostat or in the winter put a bypass valve of some type.
Old 12-25-2009, 06:52 PM
legacycycles's Avatar
legacycycles
legacycycles is offline
Oops
All solid answers.I ran 60wt amsoil with cooler never had an issue.
Old 01-07-2010, 11:33 PM
Daddy's-Ol'SHVL's Avatar
Daddy's-Ol'SHVL
Daddy's-Ol'SHVL is offline
Baker 6into4 tranny? Worth the money? I want one.
Old 01-08-2010, 01:58 PM
78fxs78's Avatar
78fxs78
78fxs78 is offline
Cooler is optional, they didn't start putting them on till 75 years later, no good if its 60 degrees or less out. I'm re-doing my Low Rider right now and I'm putting the factory one back on only cause I'm going back to completely stock original with it.
Quick Reply: So...how important is an oil cooler?
