Circuit Breaker locations
Old 06-30-2010, 08:54 AM
bubba78flh's Avatar
bubba78flh
bubba78flh is offline
Stage IV
Default Circuit Breaker locations
Hi, I have a 78 FLH and I am trying to locate the lighting circuit breaker. I found 2 under the seat, but I'm not sure which is which. I know there are 3 on the bike, according to the manual. Any help will be appreciated.
Thanks in advance,
Bubba
Old 06-30-2010, 09:41 AM
panz4ever's Avatar
panz4ever
panz4ever is online now
Received 3,210 Likes on 1,480 Posts
For 78 I think there are 4 breakers on a stock 78 FLH...main circuit breaker off battery + side, lighting, ignition and accessory which were mounted on the underside of the dash plate.
Is the wiring original? Post a pic perhaps?
easiest way to see which breaker operates the lights is to disconnect one of the wires and turn on the switch. Lights will not come on with wire disconnected.
Old 06-30-2010, 10:35 AM
bubba78flh's Avatar
bubba78flh
Stage IV
Thanks much. I was just poking around and I found the other ones under the dash. I think I found the lights one. Reason I need to check is I think I have a short somewhere. I turned the lights on and than hit the front brake and I lost the headlite and the rear lites. Directionals still work though. Still plugging!
Thanks,
Bubba...
Old 07-03-2010, 07:11 AM
bubba78flh's Avatar
bubba78flh
Stage IV
Found the problem. It was a short in the front brake micro switch. changed switch and all is well. circuit breakers checked out ok.
Macky1986
11-11-2011 09:34 PM
Staggerty
07-08-2011 12:24 PM
Jukebox
02-19-2009 06:20 PM
84 SOFTAILCUSTOM
04-29-2008 08:03 PM
52edub
11-10-2007 04:35 PM
Quick Reply: Circuit Breaker locations
