Shovelhead, Best Years
Can someone please tell me the best years Shovelheads were made.
Thinking of buying an old school shovel that I can convert into a "David Mann" looking machine.
Want to stay away from the severely problematic years; my understanding is some AMFs were really bad, others not so much.
Appreciate all feedback.
Everybody is going to have a different opinion of The " best years " . Myself I'm real partial to the 70 - 74 models and the 80's bikes with 80" motors were pretty good for the most part I just didn't care for the trans & shifting on those , and the 74" motors are tractors treat them half way right and they run forever . The only ones I'll say skip on and here comes the flames are the 1977 - 78 - 79 years , they had all kinds of problems with everything . Harley basically tossed parts together and made bikes what the numbers say it is most times is wrong . Engine cases weren't machined right , bad cam bearings & nose cone fit , frame breaking in a couple of spots ,some of the cylinders had a .006" taper on the head gasket surface , egg shaped bores , ect . I worked at a dealer during that time so this isn't hearsay , ok . But on the up side every problem that could arise on a shovel there's a tried and true well known fix for it out there , good luck shopping I've had my 72 shovel 28yrs now
Puttnutt24 (08-19-2023)
Received 3,214 Likes
The best years...1966-1984. Think about it...unless you find a museum piece, shovels only survived because the problems were fixed by the previous owner.
AMF years were a blessing and a curse; MoCo buy back was a double-edged sword.
Sounds like you are gonna modify what you purchase, so just look for a scoot with CLEAN numbers, solid motor/tranny and go from there
The following 4 users liked this post by panz4ever:
You can also build your own Shovel. Just find a cheap buy on a "Non-Running but with clean papers Shovel. Go to just about any reputable aftermarket engine manufacturer and get a new Shovel with the improved internals. Just be sure to get the Point of Origin Certificate to male registering it with the new motor. This way you will have a Known ride, not a questionable one.
One thing I really loved about my old Shovel was I could just about fix any problem found when on the road. They were very reliable and easy to fix when they did break down.
Early shovels 66 thru 69 great ! AMF take over years 71 thru 73 problems with things like pinion shaft oiling after 74 got better by 77 pretty reliable I had a 781/2 put 45K miles (converted from Prestolite electronic ign to points at 20K put in an A grind cam/ solid lifters ) I still have a 52 pan/shovel kick only love it !
I'm the 3rd owner and the bottom end is still original never been apart. But it sat for 12 years. I've had it around 13 years now.
Sounds like you want a cheap one to build your own thing. Just star hitting Craigs list everywhere, Ran across one the other week 3500 running bike.
Yo , let's not get into a dick wagging contest because your panties got little tight over a generalized statement . The man asked a question and I gave an answer based on a lifetime of dealing with other peoples broken **** including a couple of years as a mechanic for a midwest states Harley dealership during the years mentioned , Ive still have a 3" thick book of of the service bulletins & recall repair notices somewhere , 75 % of the bikes I've repaired or helped somebody with are those 3 yrs mentioned , 1978 being the biggest offender for owner aggravation . Not major things most times , just a continual series of little things that get worse . When you keep records it comes down to numbers bud not just personal opinion . Every year had it's quirks some more than others . The bikes are all the same to me , I just see or hear whats needs to be fixed anymore , bad habit maybe but I,m the guy who they come see when all the shops around here won't touch their bike . What are you bringing to this discussion besides an opinion and wise *** attitude ? Be nice I have no interest in acquiring any more bikes or parts .............
As a another poster said by this point they are all pretty much sorted out over the years , if your the 3rd owner you didn't get any cherry there now did you ? But really that's is a nice looking bike I very rarely see anything remotely stock anymore .
