More pogo stick help please?
Ok i have the 77 fxe that i want to put a pogo stick in. the down tube is hollow all the way thru. What does the stick fasten to that keeps it from just falling out the bottom of the tube. Am I going to need to weld something to the bottom of the tube to keep the stick in place? thanks for the assistance in advance.
more information on pogo stick.
yes there is no hole on the bottom of the down tube for the nut to tighten up to. should there be a plate welded to the bottom of the tube? MY down tube is hollow the same size at the top all the way thru the bottom it measures 1 1/8 inches both top and bottom. thanks again.
yes, you'll need to weld something on the bottom,like maybe a thick bushing with the hole big enough for the threaded end of the pogo to slip through,weld it up good cuz she might buck you off if it hits the ground. another thought,is the pogo going to be the right diameter ? i could measer one i have laying around if ya have'nt bought one yet.
regards,
from me
regards,
from me
Received 3,209 Likes
Seat post bushing are available through J&P and V-Twin. Once you get them in place its just a matter of sizing them to fit
i used a tape to measure[could'nt spot my caliper] but its 1&16th or 1&32nd,so you'll be ok on that. the lenght should be ok, now if you weigh over 200 pounds like me, there adjustable to an extent,but i still bottomed out on a big bump,so i read a post that i guy put up about bottoming out and he took a valve spring off an engine[i used one from a small block chevy] and put it right over the post between the t-post and frame so when it goes down you'll have extra spring and takes the shock out of bottoming out. i have an air bag setup from a cop bike with tank that mounts in side bag,going to mount it this winter,im old so ill do what it takes, at any rate you'll enjoy the ride,and it will be worth it,you guys have a good day
