new starter drive hanging up
Old 10-30-2010, 11:11 PM
alabamatbome's Avatar
alabamatbome
alabamatbome is offline
Stage IV
Default new starter drive hanging up
just put a new starter drive and starter relay on my 76 shovel also had the starter check out shop said it was in good shape not draging or anything now when i hit the starter botton it hangs up keeps going till i pull cable off starter drive never ran across this before can anyone help
Old 10-31-2010, 09:19 AM
sqdealgeorge's Avatar
sqdealgeorge
sqdealgeorge is offline
This problem usually starts with a discharged battery Happened to me several times to the point of leaving the seat loose to get at the bat connections when the starter did not release Good bat / charging system good to go
Old 10-31-2010, 09:35 AM
Twin2's Avatar
Twin2
Twin2 is offline
had same trouble after changing clutch hub - this worked for me - loosen all bolts on outer primary and move it up and to rear - give it a try
mballard
Shovelhead
31
06-06-2019 08:01 PM
chrisfharley
Engine Mechanical Topics
04-07-2014 05:02 PM
dkaat
Shovelhead
09-06-2012 02:46 AM
MMCHD
05-17-2012 08:06 AM
Joker441
Shovelhead
02-08-2006 04:56 AM
Quick Reply: new starter drive hanging up
