Age-old oil leak around transmission output
I'm assuming you are running a ratchet top 4speed. I'm also assuming you have a fresh tranny. On pre-78 1/2 4 speeds there is a very tiny "L" key (PN 35175-38, 1941 to1977 spacer key) that locks the spacer to the mainshaft between the mainshaft seal and sprocket. I left this out once and had leaking problems until someone asked me if I had put the key back. When I replaced the key, my leaking problems ended. The 78 1/2 (cow turd top) and later 4 speeds eliminated the key.
Look in your shop manual. It is very small and can be easily missed. A lot of the time, it will come off with the sprocket and fall off and lost to history.
Ok, I did some research and the key thing does not go with my '78.
The little L key is part number 35175-38 and it fits into spacer number 35171-37 but both of these parts are specified for models up to early '77.
From late '77 to '79 the factory uses spacer number 35070-77.
35070-80 is used for '80 and '81.
35070-82A is used for '82 and '83 belt drive FXB models.
35079-82A is used for '82-forward except for belt drive models.
Nothing after early '77 uses the L key.
Im wondering now which spacer I bought. I assume it is the one specified for a '78 FXS, the 35070-77.
Im wondering now if the 35079-82A for '82-forward is what I need. Or, should I go back to the pre-early-'77 set-up with the L key.
Gets complicated.
Gets complicated.
Stay with the late model stuff the lip on the spacer is bigger , better support all round for torquing it down . Clean everything with brakecleaner and smear a light coat of permtex Ultra Gray around the splines where the spacer sits against the sprocket torque it and let it dry overnite , found that little trick and get you a reprieve for a while if a teardown isn't in the books for a while .
Gets complicated.
Gets complicated.
