"Electronic" ignition switch
Old 10-20-2011, 03:20 PM
boxfullofbluze's Avatar
boxfullofbluze
boxfullofbluze is offline
Default "Electronic" ignition switch
Need to replace my ignition on my 81. Can somebody tell me what is "electronic" about a electronic switch and should I bother or just go with mechanical.
Old 10-22-2011, 06:34 AM
TwiZted Biker's Avatar
TwiZted Biker
TwiZted Biker is offline
Received 47,839 Likes on 17,455 Posts
No difference in how they work internally , the mount & the terminals are different instead on the normal little 5 screw mounts there 3 spade terminals and they use the round key instead of the old flat style
Old 10-22-2011, 08:46 AM
Tom84FXST's Avatar
Tom84FXST
Tom84FXST is offline
Received 18,167 Likes on 5,391 Posts
They make the "electronic" version that the catalogs sell that is a direct replacement for the mechanical. It is easier to turn than the mechanical, and has a much better "feel". They do not hold up as well to the elements...if you ride in the rain a lot expect to replace it in a couple of years.
Old 10-22-2011, 04:28 PM
boxfullofbluze
Ok Thanks ..I think I'll give it a try ..Around here ,if you don't ride in rain ... you hardly ride ..
sgl0226
02-22-2021 06:24 AM
sixty7flh
Electrical/Lighting/Alarm
09-26-2014 08:36 PM
jrotis215
EVO
07-13-2014 07:08 PM
YtseJam
08-08-2010 03:51 PM
F1J1
07-14-2007 07:28 PM
Quick Reply: "Electronic" ignition switch
