S&S E carb on 1340 shovelhead ?
Down side is cost S&S the last 6 years or so has really gotten a big head and rather proud of their prices , bad as the MoCo . If budget is a consideration or you have some mechanical skills pick a late CV carb and do the rebuild and tweaks with some new parts . Those will really turn on a shovel done right and tuned properly you can get upwards of 50-54 MPG with one , something to consider with your prices over there .
My hat's off to you man I never could deal with those .
S&S E is hard to beat imo...as stated easy to install and tune...last one i bought was in 95 for a 79FLH 1200 stock, called S&S, answered a few questions about motor and pipes so it would be jetted for my set up...bolted it on and ready to go..bike has always started good cold or hot...i also saw jireh cycles sells an ultima carb (S&S) for a couple hundred less, same carb
Get a CV, put a stock spring and unmodified slide in it, get a Drag part #DS-195100 jet kit and use the emulsion tube needle and 45 pilot jet, get an appropriate main jet for your build, most likely a 180 or 185, pop the A/F screw plug out and set it to 1 3/4 turns out and go for a ride. If it coughs on roll on give an 1/8 turn more until it stops. Costs about a third of a new E and will run better!
