77 fxe front end
Old 04-29-2012, 07:47 PM
nebrown1's Avatar
nebrown1
nebrown1 is offline
Default 77 fxe front end
So i have a 1977 fxe with a 35mm front end. I just got done rebuilding it and when i put it all back together it was leaking oil out of the top seal of the lower leg were the tubes go throw. As far i i know they are the stock tubes do you guys thing i need to buy new tubes maybe there worn. or did i mess something up?
Old 04-30-2012, 10:30 AM
msgtarmor's Avatar
msgtarmor
msgtarmor is offline
What did you use to put the new seal in? If you have the proper tools then it just may be a defective seal. If you use a punch and hammer then you probably dented the tube or damaged the seal and will need to be replaced. I use to use the punch and hammer method and after ruining 2 fork tubes, I figured it's cheaper to buy the right tool! I also figured out you can use the appropriate size of Schedule 40 PVC a few inches longer than the tubes as the 'tool'.
Hope this helps ya!!
jim
Old 04-30-2012, 10:07 PM
nebrown1's Avatar
nebrown1
nebrown1 is offline
I used a PVC pipe to put them in. i guess i will just order some new seals and hope for the best. i guess if it doesn't work ill buy some new tubes.
Old 05-01-2012, 09:50 AM
msgtarmor's Avatar
msgtarmor
The PVC pipe works well! When you have it apart inspect the area where the seal slides on the tube. If there are any flaws, nicks, scratches, etc you may need to replace the tubes. Are you using seals from HD? I do and the only times I have problems sealing is when I screw up on the installation of the seal or it gets worn out. 2 of my bikes have raked frames so they're a little harder on seals.
As a side note, you might want to replace all the slider bushings. If they have been in there since day 1 they could be worn and causing too much play so the seal cant do it's job.
jim
Old 05-01-2012, 10:03 AM
Edward Brown's Avatar
Edward Brown
Edward Brown is offline
Slider Bushings ?
Old 05-01-2012, 01:03 PM
TwiZted Biker's Avatar
TwiZted Biker
TwiZted Biker is offline
Received 47,834 Likes on 17,453 Posts
Where you live ? I've got a few set's of good stock tubes and some seals for those .
Old 05-01-2012, 03:01 PM
msgtarmor's Avatar
msgtarmor
Originally Posted by Edward Brown
Slider Bushings ?
OOPs! Yer's is a 77 so it aint got none!! I was thinkin of 84 and later forks. Bummer cuz they are cheaper to replace than sliders that are worn out.
Anyway, I'ld check the fitment of tube inside the slider without a seal in it to see if they are too loose.
The book doesn't give a measurement for too much. It just says "1973 and later sliders do not have removable bushings. If slider is worn to excessive looseness on fork tube, slider must be replaced".
Sorry about the misleading info there!!!
Ya might hafta take 'Twisted Biker' up on his offer or at least keep it in mind!!
jim
Old 05-02-2012, 12:03 PM
nebrown1's Avatar
nebrown1
nebrown1 is offline
I live in MA
Old 05-02-2012, 12:37 PM
TwiZted Biker
I'm in Cal. unfortunately , you may have just damaged the sealing lip on the seal . Those tubes unless they have rusted a bit or have been damaged in some way are pretty hard to hurt wear wise the lower legs got before the tubes do most times . The early front took less oil too so maybe recheck that ?
Old 05-02-2012, 05:51 PM
nebrown1's Avatar
nebrown1
nebrown1 is offline
I put 6 oz in each leg. Idk I just order some new seal and them I will pull it all apart and rebuild them again. Would you be will to ship thoses legs? And how much you looking for them
Doug 64
08-09-2013 02:54 PM
98glider
EVO
16
06-16-2012 07:02 PM
joel_157
07-19-2011 10:41 AM
Figstr
10-09-2009 02:28 PM
SkyRider
04-24-2008 07:56 PM
Quick Reply: 77 fxe front end
