Full of Fuel
Old 08-21-2012, 11:53 PM
Locadd's Avatar
Locadd
Locadd is offline
6th Gear
Default Full of Fuel
Hi to all,
I have a 1980 74 CU Superglide,
I had trouble getting it to start after it was trailered home a few weeks ago (another story)
It has single fire ignition and has never been a problem to get started. Anyway after kicking the living hell out of it nothing at all.
I then removed the spark plugs to see if it was getting any fuel – the rear cylinder was absolutely full of fuel. After kicking it over for another few times it spewed a **** load of fuel and oil out through the crank case breather all over the garage floor.
After changing the oils and filter and putting the plugs back in she fired up on the first kick like it always did.
So here is the question does anyone know what could have caused the cylinder and crank case to fill up with fuel?
Cheers
Locadd
Old 08-22-2012, 12:22 AM
rickss69's Avatar
rickss69
rickss69 is offline
Trash in float bowl holding the needle open most likely. Many petcocks are notorious for passing fuel even in the off position...or not passing enough in the on position.
Old 08-22-2012, 04:34 AM
AlCherry's Avatar
AlCherry
AlCherry is offline
Right. BTW, what carb are you running? Some were notorious for dumping fuel like a Bendix, Linkart and early HD's Keihens. The petcock is also a culprit in this crime.
If you drop the bucks and get you a Pingel petcock you can stop that problem. Or you can do like I did years ago and carry a set of vice grips and pinch the line when you stop. (I'm glad I quit doing that). I'm glad the bike didn't start with all that fuel in the low end. You had a potential bomb on your hands if the fuel and fumes had lit off.
Old 08-22-2012, 03:27 PM
Locadd's Avatar
Locadd
Locadd is offline
6th Gear
Thanks for the advice guys, I can’t be sure if I had the fuel turned off while the bike was on the trailer, as you stated I am also glad that it didn’t fire up while it had a belly full of fuel as that could have been quite disastrous.
Cheers
locadd
andrejak
09-12-2012 03:25 PM
Wild Billy D
09-13-2011 07:17 PM
katobird
12-24-2009 02:03 PM
wingman1946
09-29-2009 04:00 PM
dewhurstaj
07-19-2009 09:34 AM
Quick Reply: Full of Fuel
