Dual Plug Shovelheads any advantage
Old 08-25-2012, 08:07 PM
Locadd's Avatar
Locadd
Locadd is offline
6th Gear
Default Dual Plug Shovelheads any advantage
What are the advantages of converting my heads to dual plug?
Any advice on this subject will be great
Regards
Locadd
Old 08-26-2012, 01:43 AM
TwiZted Biker's Avatar
TwiZted Biker
TwiZted Biker is offline
Received 47,834 Likes on 17,453 Posts
Bone stock bike not a whole lot but if you have crappy gas like we do here state side it does make for easier starting and ignition fine tuning , plugs last longer and it does cut way down on ignition knock & ping . If the engine has been pumped up a bit they are a definite plus . I run dual plugs on about all my shovel builds anymore on my 93" it's like I have a passenger on if I pull one set of wires , that much difference in performance .
rockher_man (01-08-2020)
Old 08-26-2012, 05:45 AM
AlCherry's Avatar
AlCherry
AlCherry is offline
As with any motor vehicle manufactorer, Harley gives us the minimum we need to get down the road. I wish they would dual plug every motor they produce. With the fuel getting crappier by the month, as stated before, dual plugs give tunability to overcome it.
Just make sure the folks who are going to drill and tap the hole know what they are doing, or you'll just have a set of ashtrays. Or you can put the OEM's on the shelf and spring for a set of S$S with dual plugs. Then there's the ignition to go with it and the stroker kit.........
Old 08-26-2012, 07:20 AM
prodrag1320's Avatar
prodrag1320
prodrag1320 is offline
i agree,the factory should have dual plugged every shovel & iron XL.on high compression motors its a must,but even on bone stock motors,its still a good idea.if you do it,use 2 6v coils,then wire them in series
Old 08-26-2012, 12:22 PM
TwiZted Biker
Gotta have them in a domed compression chamber like shovels have , Evo & twinkies with the flat tops and no hemi head duals are a waste of money .
Old 08-26-2012, 01:54 PM
biginchhustler's Avatar
biginchhustler
biginchhustler is offline
Old 08-26-2012, 01:57 PM
biginchhustler
Size:  84.5 KBIF you can TIG or know a tig welder who can weld old used cast aluminum its best to have a bung made to fit the side being converted. his way you have 2 long reach plugs..
Old 08-26-2012, 02:00 PM
biginchhustler
THIS IS FOR THE OLD TIMERS WHO REMEMBER THE SIFTON CAMS.. ITS AN OLD SIFTON CAM SHEET FROM THE 1970'SName:  SIFTONCAMDATA.jpg
The following 2 users liked this post by biginchhustler:
rockher_man (01-08-2020), Uncle Larry (07-02-2018)
Old 08-26-2012, 03:04 PM
Locadd's Avatar
Locadd
Locadd is offline
6th Gear
Thanks for all the advice guys, I have a local shop that has done a few duallug conversions. They have quoted me $240.00 to do the job. My engine has only done 4400 miles in the last 6 years so I intend to refresh the top end while I am giving the whole bike a B/D. So I may as well go the whole way while it is pulled apart. I will post some progress photos over the next few months.
Cheers
Locadd
Old 08-26-2012, 06:26 PM
AlCherry's Avatar
AlCherry
AlCherry is offline
Welcome back Kirby, haven't seen you in a while. Looks like you got some rain coming.
Quick Reply: Dual Plug Shovelheads any advantage
