Shovelhead rigid frame? FL,FLH,FX, Electra glide etc etc
Good day Harley members,
I am totally new into Harley's, always and still have ridden only Ducati's.
Now I'd like to built my own Harley Rigid.
It must be a shovelhead, so after a little research on the net, I have found that the FX models are easy to weld a hard tail on it.
But now it comes, I am looking for a good frame are the frames from the models FL, FLH, FX, electra glide, etc etc, say from 1966 till 1983 the same?
Gr, Nick (NL)
Gr, Nick (NL)
lotsa luck as people think these frames are gold -- check ebay -- http://www.ebay.com/itm/Harley-David...374fd6&vxp=mtr -- http://www.ebay.com/itm/Harley-Shove...279ce8&vxp=mtr --- http://www.ebay.com/itm/Harley-David...37735d&vxp=mtr -
"theres 3 of them on fleabay
Personaly, I think you should go with a aftermarket frame rather than butcher a stock frame. There are a lot of great frame builders out there, and the prices are reasonable. I'm sure there in the Netherlands there are really good frame builders. You can get frames in a variety of metals from steel to moly. Many aftermarket frames leave enough room for stroker motors. A little internet research should get you going in the right direction.
If NL is like Italy (where I come from) it is a PITA to deal with anything that ino non STOCK oe EU approved.
He probably need a clean frame/engine combo
Over here in the States is SO easy to build almost anything,,, pick up this frame, this engine, do this, do that, minimal paperwork.... you don't know how lucky you guys are!!!
Anyway...I am going through the same here... since it's too easy to build a custom HD, chopper, etc...I looke for a matcing numbers clean shovel.. orginal frame, ok runner.
I will build a chopper but want to keep the frame OEM... have a bolt on rigid for it. I want my bike to be a REAL HD...not just a bunch of parts that look like an HD
I 2nd that -- theres LOTS of ridged frames on fleabay
I do this in english because otherwise the rest won't understand my dutch.
If you go for a 4-speed frame you have to go 1985 or before. The 1986 fl models are rubber mounted evo with an ugly square backbone.
But if you go to L&L ore a company like that they can give you advice on how they do this and get it road ready.
Good luck
Good luck
