4 speed: starter clutch gear key, kickstart side
Old 03-24-2013, 09:22 PM
V_twins's Avatar
V_twins
V_twins is offline
Default 4 speed: starter clutch gear key, kickstart side
Hey guys...
I got a kickstart kit for my 4 speed I am about to install
Going through the hardware I think the shaft key on the kickstart side is missing:
http://www.jpcycles.com/catalog/2010...?entrypage=110
OEM 33393-50, item V on page 108 on the link above
Does anybody know the specs/size?
Before I order it and wait for it to get here, I was wonndering if I can get one at a hardware store knowing the specs
thanks
Old 03-25-2013, 05:08 AM
johnjzjz's Avatar
johnjzjz
johnjzjz is offline
Received 4,528 Likes on 2,867 Posts
i will measure one today in the shop - its square like a small shoe box not like a normal key way - its a left over from the jD days - a lawn mower shop might have that size as they still use that type key -- but i will get one and measure it for you - jz
Old 03-25-2013, 08:13 AM
V_twins's Avatar
V_twins
V_twins is offline
thanks man!
Old 03-25-2013, 03:48 PM
johnjzjz's Avatar
johnjzjz
johnjzjz is offline
Ok the shoe box looking square key is
L .385 X W .188 X D .152 and the OEM - 50 part number is the correct one
are you sure its not taped to in inside of the box / packing its never just loose -- jz
OlGrampy
Ironhead
05-01-2011 09:34 PM
Bama91
EVO
02-23-2011 06:48 AM
customsoftail200
Electrical/Lighting/Alarm
11-05-2010 07:54 AM
bgh4hrlyd
08-16-2009 11:00 AM
HD47knuckle
Shovelhead
08-19-2008 07:37 PM
Quick Reply: 4 speed: starter clutch gear key, kickstart side
