Battery not charging
I took sandpaper and cleaned the points in the voltage regulator today and now the gen lite goes off at 1500 RPM,i am still not seeing any change at the batt if i hold the volt meter to it and reving the bike up.Is there an ajustment on the regulator to up the volts from gen to batt. Driving here is a lot of short runs,mostly city driving.
old thread -- charging systems...
not sure if this will work,, but try to pull up this old thread..
https://www.hdforums.com/forum/shove...ng-system.html
if not search on charging systems...
i had the same issue last year, and the folks on this page provide some outstanding trouble shooting steps...
my problem was the voltage regulator....
good luck
mb
good luck
mb
Try checking out the water level of battery if it goes down or what? Also look out whether poles are corroded or else? I used to check batteries while motorcycle shipping. So, I know some do's and don'ts about battery cautions.
WrenchinRider
08-10-2013 08:28 PM
