Adding a Kick Start
Old 05-18-2013, 11:13 PM
jim70's Avatar
jim70
jim70 is offline
Default Adding a Kick Start
Looking to add a kick starter to my 74 FLH. I can see where I may run into clearance issues with the exhaust header.
Before I get too far into this..can it be done? or am I going to have to look at exhaust work to allow kickstart fitment.
I'm just sizing up the kickstart cover and coils spring over the currently installed cover.
Your comments and guidance appreciated.
Thx
Jim
Old 05-19-2013, 08:06 AM
johnjzjz's Avatar
johnjzjz
johnjzjz is offline
Received 4,536 Likes on 2,872 Posts
your correct about the exhaust, the OEM exhaust drops down and covers 1/2 the kicker cover - the after market exhaust does not it goes around the front of it -
the kicker kit is not to bad to install but you will need an exhaust change to do it - jz
Old 05-19-2013, 07:38 PM
biginchhustler's Avatar
biginchhustler
biginchhustler is offline
check fleabay -- sometimes you can find just the rear pipe -- shovelhead exhaust
Old 05-19-2013, 10:41 PM
jim70's Avatar
jim70
jim70 is offline
But I thought the pipes were a 'one piece' arrangement with the crossover that slides into the left side behind rear cylinder.
Jim
Old 05-20-2013, 07:36 PM
johnjzjz's Avatar
johnjzjz
johnjzjz is offline
some were and some were not one piece usually the original is one piece but a 35 year old bike might have a replacement -- jz
Old 05-20-2013, 09:36 PM
TwiZted Biker's Avatar
TwiZted Biker
TwiZted Biker is offline
Received 47,919 Likes on 17,474 Posts
Thx
Jim
Get a pic ( use photobucket ) of your pipes on the bike close in and I can tell you if it can be done and what it'll take . Some FL pipes will clear with an extended kicker shaft others won't .
Old 05-21-2013, 12:18 AM
jim70's Avatar
jim70
jim70 is offline
I'm on the road..actually in the air..
Dropped u a PM.
Thx
Jim
Old 05-22-2013, 06:31 PM
FilthyLucre's Avatar
FilthyLucre
FilthyLucre is offline
Cheapest way is to buy a good quality kit. It gives you all the parts and gaskets. You will have to get aftermarket pipes to clear the cover. Not as much selection as their used to be. FX pipes will not work unless you change the battery box and brake set up.
Old 05-23-2013, 11:57 PM
jim70's Avatar
jim70
jim70 is offline
Bummer,
You'd think there was an easier way out...for the sake of a few inches of clearance on the cover...
Old 05-24-2013, 01:58 PM
FilthyLucre
Why Harley made the decision to change the pipes is beyond me. The 66 to 69 pipes cleared even after they removed the kickstarter in 67. They used the same cover with just a plug in it. I imagine you could use 66-69 pipes. They were multipiece. A separate front and squish pipe, a rear pipe, a Y pipe and on some models a crossover. The front pipe looped forward to clear the generator then under the frame and had a flat section that came out between the frame and the motor to join up with the Y pipe.
bdtaylor1979
06-21-2019 10:49 PM
T Man
04-29-2017 12:59 PM
FL54
Shovelhead
09-19-2016 09:02 PM
17black
01-01-2011 11:07 AM
Trek
Exhaust System Topics
08-10-2008 09:59 PM
Quick Reply: Adding a Kick Start
