Keep burning up solenoid to starter cables...
does the wire coming off the smallest post on the solenoid go to the "S" post on relay or one of the large posts on the relay?
thanks in advance.
I don't have the four connector type relay, mine has three.
So I can't speak to which smaller post to use. If you have an ohm meter, you can figure out which one to use.
So when you know which smaller post to use, that gets the wire from the starter button.
It doesn't matter which large post gets the wire from the battery or the wire that goes to the solenoid They are both isolated from ground (or should be).
To recap, connect the wire from the starter button to the small post that operates the relay. Make sure the metal plate that the relay is mounted on is grounded.
Connect a wire from the positive side of the battery to one of the large posts and then connect a wire from the other large post to the small post on the solenoid.
no, the large posts are not polarity specific. if you use Mega's schematic, then you would unhook the small wire to the solenoid and hook it to the small terminal ( S ) on relay, then run batt. ( + ) to large terminal on relay and run a wire from solenoid ( small terminal ) to other large terminal on relay. probably confused everyone at this point, me included. and NO negative(-) anything gets hooked to any solenoid or relay (should ground for the coil through the body)
dang it I thought maybe I missed something when I put it back together...
I have attached what is my current understanding of what my starter circuit should look like and it is in fact how i am and was configured when i burned up two starters, two solenoids, and 2 starter to solenoid cables...
Somebody please advise WTF...
I am really confused at this point...
Yeah, problem is my wiring is the same now as when i took it down to fix tranny oil leak and was otherwise working fine...
Put it all back together, fried battery, starter and solenoid, and solenoid to battery cable 3-5 seconds after first bump of starter button...
After replacing all that shiite and checking everything with a meter, finding nothing; and thinking maybe the starter cable grounded against the bracket on the back side of the starter the first time; cause the oem hitachi setup is pretty darn close to begin with...
2nd try was a instant repeat of the 1st...
and there was no way the spyke starter cable could have grounded against anything this time around...
So... i really want to find something definitively wrong before i put another 400-500 bucks worth of parts on it...
Only damm wire frying is the stinking 4 gage solenoid to starter cable...
