79 fxs lowrider oil Wt?
Hello everyone i live in Ohio I have a 79 lowrider and i'm not sure what oil Wt i should run in the motor? i do not rider in the winter. i know the book is telling me to run 60 Wt(over 80 d ) but i had a mechanic tell me a should run 70Wt in a iron head motor.that seems a little heavy to me but i don't know. any info would be helpful thanks for looking
Ok 2 things do not use the term " Ironhead " when talking about about a shovelhead , Ironhead was the old sportsters which had cast steel heads where the shovels are aluminum big difference .
Second thing shovels due to the crappy hydraulic lifter & oiling system do not like 20-50 multi weight oil they get real noisy and they will smoke more as the multi oils gets past the valve guides don't ask why but it does , use 50 or 60 straight weight and maybe 70 if the bikes high milage or it goes over 100 regular during the summers . Been building & riding pans , shovels and old brit bikes pushing 40 years , this has proved out many times over .
when I go up north (Pa.) I run 70 in the summer and 60 around now -- I use NOTHING but ULTIMA oil - and militec 1 -- my bike is on 5 years when I change the oil theres NOTHING on the magnet -- I have the spin on oil filter that's sits by the voltage reg..
seen a few people run the 20/50 some swear by it -- stock hyd lifters wont work -- they will make a racket --
good deal on ultima 70 wt -- http://www.ebay.com/itm/360372019276...84.m1439.l2649 ---
$72 a case free shipping --
need other weights??
David Burrill
707-706-FMBC
David Burrill
707-706-FMBC
Scrapple ? OMG haven't seen that **** since old grannies general store way the hell out in the woods near the Virginia border where the hillbillies walked in outa the woods . You do know what that stuff is made of don't you ??
