1977 superglide no start just a clicking sound
Started with a bad battery caused a melt down and now I have a new battery, solenoid and solenoid switch. I have the starter out of the picture now and cleared off the solenoid. I cant get the solenoid to pull in and all the wires have been replaced to the diagrams. I see a voltage drop at the solenoid when I hit the start button about 10 or 11 vdc not enough I guess ? I can jump the solenoid and it will pull out the jack shaft like a slick cat.
Thanks yes a new battery with the most cranking amps was my last donation
a second solenoid switch also and all the engine grounds are new/ the bike is a restoration about three years ago mostly all new. I did not check the ignition breaker that is a could catch as I will see/ thanks much !!
LowRider HD
Electrical/Lighting/Alarm
08-31-2013 06:55 AM
