Need a simplified 5 Pole Ignition Switch Wiring Diagram...
Received 3,222 Likes
Hi guys I'm new to form, as well as HD & old school bikes (Shovels) , and have a question on above. Should there be a 15 amp breaker between each of the ignition switch terminals and the various wiring. Example: between Post 2 and the H/light, T/light, D-Signals, their switches and speedo lamp, and one between post 5 and Neutral/Oil/Gen switches and lamps?. Right now my NEAR basket case 79 FXEF (76 FLH Shovelhead engine) has everything coming off of one breaker, which occasional trips and takes everything off line until it resets.
Previous owner pretty much stripped/chopped out all the signals, controls, switches & lamps and I'd like to get it back to where it should be. I built a secondary harness for the missing lights/switches/lamp components, and the old harness (ignition/coil, starter, H & T lights) seems OK.
Thanks in advance
Thanks in advance
