Rebuild time
#31
#32
i know they at S&S say its for an Evo - we have used them in shovels BUT you might have to close the primary from the engine and add oil to the primary one cup 16 OZ type of thing - some work with a ripped breather like you have and some dont -- just so you know
#33
no problem closing the primary
I guess the standard size gear would work? the bigger one if for cases that have been machined?
At some point I wanted to add a cam as well... and you were suggesting Andrews AB with longer exhaust duration (80" shovel, oem pistons, new 6 speed transmission RevTech gearset, 0.86:1 6th gear, CV carb, no voes)... but maybe I would wait a little and see how I like teh current configuration... or I can do that later and replace the cam bearing and check how things are down there... ?
