Eliminate Speedometer Cable From Transmission
I am doing some cleanup work on a Shove project I've been working on. I want to eliminate the speedometer entirely. I noticed that the mechanical cable plugs directly into the transmission. My concern is that the cable tip seemed to have oil on it when I unscrewed it. Do I need to track down a plug to seal up this hole?
Thanks for the heads up, johnjzjz. I tracked down that plate kit from the J&P web site. In doing some more digging, I think what I might be seeing on the end of the square cable is lubricant, and not oil from the transmission. I'll probably try my luck and run without the cable hooked up until the block off plate comes later this week.
Cheers!
Cheers!
