Will these brakes easily fit on an '83 FLHS?
Received 4,118 Likes
Gma brakes work real good on grandmas walker - the one for the front wheel
the rear wheel one works - brake pads are often the reason they are not better as no bothers to make a good pad for them < that should help
in my shop if they show up with it we install it but i wont sell them as the cusomer will always come back and say you need to ride my bike and tell me if those brakes you put on stop OK -- jz
Gotcha...so the consensus is...
*GMA brakes....not very good
*These are single piston...so only good for stopping sporties...not larger bikes..and since I wide with the wife on the back...even less of a good idea.
My rear caliper locked up on the highway last year..the stock Harley one...had a good meltdown. Looking to replace it. Front one still fine and still mounted. Guy is asking 250 for the pair.
**Even if I put good pads on them ...still stink?
Here's a (large) picture of the side of my bike, showing rear brake.
I don't think the rear caliper is actually a banana type. But...just wish to get something good on her.
http://www.speedguide.net/~brian/flhs13.jpg
I mounted as a link instead of a picture that opens because it's large..don't want to slow down everyones browser.
Yep, you're correct, I forgot that HD had moved away from the banana for your year. The GMA rear will likely do just as good of a job and look a little better on the rear. My heartburn, and John's as stated above, is that the front isn't much of a brake for even a lighter FX-style bike, let alone your FL riding two-up.
Just for kicks, while you're searching for some replacement brakes why don't you bounce out to Fab Kevin's website and see what I mean about his brackets and the jap-bike brakes. I'll bet I've got less into that entire setup for my 77 FL (both 4-piston calipers too) than what this guy is asking for the GMA brakes...
www.fabkevin.com
www.fabkevin.com
www.fabkevin.com
And "Thanks" for your replies and help.
Swap meet at Stafford Springs CT in 2x weeks..might get lucky there too.
I run the same one on the front and rear as the rear you have in the pic. Both stop very well. Most folks don't run the correct rotor with them as they use a ductile iron rotor and pads for those type of rotors. If it isn't stopping correctly, they probably have on stainless drilled rotors instead for looks. Not stopping power.
Correct master cylinder bore is crucial also.
Griz
Griz
Griz
Griz
if you ride drum brake bike a lot i guess you agree they work well
they had a change in the machine department and up dated the internals ( dont know what they did ) but it was to little to late for me, as i was never able to get help from them, when they were a viable choice years back and today the stuff thats available they are paper weights -- jz
