fat boob tank mounts
Old 04-21-2014, 05:53 PM
fergerburger's Avatar
fergerburger
fergerburger is offline
Default fat boob tank mounts
Did the original fat bobs have rubber grommets for the front mounts? I'm having a hard time figuring out if there are grommets or not for the mid-70's fat boobies.
Old 04-21-2014, 07:27 PM
johnjzjz's Avatar
johnjzjz
johnjzjz is offline
Received 4,536 Likes on 2,872 Posts
No rubber --- some guys will use rubber flat washers under the tabs but the factory bolted them solid to the frame -
the softail had grommets and with center spacers on top tabs 3 each side
Old 04-23-2014, 02:55 PM
Rodney's Avatar
Rodney
Rodney is offline
Wink
some times a flat washer as a shim for alignment if need be but as John says solid to the mounts
Old 04-23-2014, 03:01 PM
Scrmnvtwins's Avatar
Scrmnvtwins
Scrmnvtwins is offline
Yep, thats the way I remember it, bolt through tank tabs to frame bungs, no rubber washers and I used Loc-Tite red to avoid riding home with my knees holding a tank half in place
Old 04-23-2014, 03:40 PM
johnjzjz's Avatar
johnjzjz
johnjzjz is offline
Caution //// DO NOT push them in and tighten the tank, space it out if you must - test install and make sure the wiring is away -- another issue to avoid
as i will crack the tank while your riding it
Gas poring on a hot motor at 60 MPH will get your heart pumping -- jz
Old 04-23-2014, 04:37 PM
fergerburger
I found a place that sells old chain guard grommets that are supposed to fit the older fat bob tank mounts...anyone heard of using such a system? I worked on a guys sporty once that had fat bobs and I recall he used thick washers on the rear mount. Is there a reason to use thicker washers on the rear mounts?
Old 04-23-2014, 04:47 PM
Tom84FXST's Avatar
Tom84FXST
Tom84FXST is offline
Received 18,202 Likes on 5,397 Posts
If you want rubber mounts...just mount softail tanks on it....plenty of kits to do that
http://www.ebay.com/itm/Bikers-Choic...-/390813349331
Old 04-24-2014, 07:30 AM
AJSHOVEL's Avatar
AJSHOVEL
AJSHOVEL is offline
Received 10,430 Likes on 4,130 Posts
Put your rear mounting bolts in the bungs first, then shim the front mounts with washers. That will keep those rear bungs from cracking (which happens a lot from impropper install)
JohnnyBombs
11-28-2016 11:01 AM
Can't Wait 2 Ride
Ironhead
08-11-2012 11:43 PM
treetop
12-25-2011 03:34 PM
dgdamore
03-03-2011 05:42 PM
Amy
07-21-2006 12:58 AM
Quick Reply: fat boob tank mounts
