1980 4 speed problems :( video inside
Hello, I've just bought my 1980 shovel and have only had it 3 weeks, I've ridden it loads but now have a problem with the gearbox, firstly it's leaked most of the gearbox oil into the primary's I hear this is a common problem so I guess I need new seals there but it's started jumping out of top gear into neutral. I took the primary cover off and when I spin the clutch it looks as if the transmission shaft is bent or something, could this be why it jumping of gear. I think it probably needs a transmission rebuild, new bearing maybe gears, urgh big expense I guess. Also someone said that it has a later evo clutch fitted is this correct, thanks for the help
View My Video
View My Video
First of all Welcome to the site -
Now the clutch assembly you have is from an 1987 type Softail and the hub should not be walking around - the 4th gear bearing might be shot causing both issues jumping out of gear and the walk you are getting --
it all needs to come apart and be looked at by a shop that does that sort of work
if you are very mechanicaly inclined than help is possable on the site if you get stuck
twistdroach
09-17-2014 08:09 AM
