4 spd clutch release shaft retainer pic
When I took apart my 4 spd I notiuced the C-clip sitting on the bottom of the cover and it was bowed....see pic 1.
I am reassembling the cover and found that there is not enough space for the retainer and that is why it was bowed. A standard 3/8 clip will not fit on the end, there is not enough space. Is there a special C-clip for this? I believe all is original parts. I bought a new revtech 4 spd 10 years ago and the clutch lever shaft just pulled out...they do not even use the clips anymore...
if i dont know actually how to fix or a way to do something i will tell you, almost all the bikes i take on are or have come from buckets and or swap meets is would seem in the shop -
this one was a basket case and is now on display in the AMCA winners circle exibit at Motorcyclepedia in newburg NY museum
