Belt drive primary compensating sprocket - got one?
Do any of you aftermarket primary belt drive owners run a crankshaft compensating sprocket? I have a 1 1/2” belt set-up with a solid sprocket and was wondering if the factory fit option would fit, or was it even worth considering. Or indeed, if an aftermarket option is available – if there is, I can’t find it.
(I’ve scanned my manual and you can see it listed as part #’s 22,23,25,26)
Would be interested to hear of your experiences – good, bad or just ’meh’.
Thanks!
John
Thanks!
John
I'm all ears.
This guy put a belt drive on his dyna and felt more vibrations w/o compensator. After a while he didn't feel it so much, but wasn't sure if things smoothed out or he got used to it.
https://www.hdforums.com/forum/dyna-...on-a-dyna.html
Cheers
they never worked correctly - that is the reason they are gone - if it did they would have kept it -
the rubber blocks back in the day did not have the stay in shape ability like the jap bikes with that set up today has --
the belts take lots of vibes out - not all - but its all in the over balance the engine has by design, it is set at 60 percent and as such spots in the rpm range are in balance than not then in again < you cant re design the single pin rod set up its been tryed many times by many people, for different reasons over the 100 years harley is making single pin V Twin motors
drake95th
08-03-2006 01:47 AM
