This true when switching to struts?
Im making a rear fender for my 82 FXE and due to my limited knowledge of fabrication, i made some brackets to make it frame mounted. Looks decent and all, but when I sit on the bike, the fender rubs the wheel pretty bad. So since I have a spring seat on it, I was going to replace the shocks with some struts from DK Customs. Recently a friend of mine said that when putting struts on a bike with a swingarm, the swingarm bolt will eventually fail due to it not being made to withstand the bumps so hard. And when it fails, well that could mean bad things while riding. How likely is this?
Received 3,931 Likes
I am 55 and have run struts on my bike with a spring seat for thousands of miles. No problems for me or the bike.
I'm 190 lbs. and I found the best ride was with 3" barrel springs like pictured below with our Solo Seat System.
All that said, I think you may be happier keeping your shocks and mounting your fender on the swingarm instead of the frame. That way you can have the fender close to the tire And have your rear shocks.
That is what I ended up doing on my ride. You can see all the details of how to mount the fender to the swingarm at this link-
https://www.hdforums.com/forum/sport...-makeover.html
Usually, when guys mount their fender that tight to the tire, the fender is mounted to the swingarm. That way, you can still keep the shocks (good idea). BTW, I like the look of that Shovel.
Oh, sorry...I didn't read that Kevin said the same thing. Good luck with which ever way you go.
kenny55
2018+ Softail Models
15
05-23-2019 08:04 AM
orangecrush
Custom Models
07-13-2007 07:55 PM
