stinkin superglide tank mount - fail
Is that pic with the front tabs under the mounting bolt?
I removed an FX tank many years ago. I'll look around, perhaps I can find the rubber block.
You are probably aware, the rear mount uses a rubber strap or spring that attaches to one tab and under the frame tube, then attaches to the other tab.
