more FXE questions - rear fender spacing
I'm still fighting with this 77 FXE basketcase I'm trying to build and I am trying to determine why the fender struts do not hug the fender...there must be about a 1/2 gap between the strut mounts and the fender. Is this correct? do you need spacers to fit the stock fender? Seems like will look like ****....my ironheads fit snug to the fender....this just does not seem right to me...I've tried two sets of struts and two fenders....verified I have shovel fenders as well.
I'm pretty sure I have the original struts for the 77 FX...they were rusted and sat on the bike in Texas for 15 years....what is odd to me is that they appear to mount on an angle...the shock mount is about 1/8" out of the smaller second strut mount on the frame...this suggests the struts are actually angled in then bowed out....I scream WHY....maybe I am missing a spacer there as well??? I got zero to go on...tons of ironheads...ZERO shovels and I'm a bit of a lone wolf....machinist in a dimly lit shop with no friends.....
I don't see a spacer pictured in the parts book for those bolts.
There is a spacer shown where the strut fastens to the "ears" on the frame.
The pic shows the bolts installed from the inside of the fender with acorn nuts on them.
Have you tried to snug up the fasteners at that point to see if the fender distorts much?
It could be the struts are slightly bent and/or the fender is slightly misshaped.
Wuzfuz, so I tried a different fender and although it is closer at the mid-bolt point it still is about 1/4" out....there is no way the fender fits snug to the frame mount where the strut bolts on....the fender is much smaller than that width so there must be a spacer that goes there.....I cam take more pics?????
