New Heads
New Heads
Hi
I have to maintain my heads.
My heads are from year 12/79 and 01/80. They had no valveseal.
To maintain the head cost a lot.
So i search in the www an found this complet new heads.
http://giveitfullthrottle.bigcartel....inder-head-set
Does somebody got any experience with this brand.
Or is it like everyone says 'You get what you payed'
Thx a lot
George
Thx a lot
George
that is a tiwan tedd head ( v twin ) they look the part and seem to work - BUT almost all of it is a bit off the intake ports are some what close and the exhaust are almost in the right spot - it has steel valves with unleaded fuel maybe 2 years and the valve job is toast
we convert the seal less heads to rubber seal with cast iron or bronze guides and the black valves all USA made for the same price with a 3 angle valve job, and glass beading over the years -- i am sure you can find a local shop that will do the same for you in your area its not rocket stuff its basic machine shop repaires -- jz
tweaked02
09-12-2017 05:00 AM
