Need tranny help with my new custom build...
Hello all, first post. I just purchased an incredible custom build '78 shovel head (I just posted a pic in another section of this forum) and I think I already screwed things but I'm not sure how I did. It's got a ratchet top 4-speed with an open primary (I think the tranny is a 1965 because the stamp says: 34703 65).
I wanted to change the gear oil - so first I checked the level which seemed very low. Below the level of the "splasher". When I drained it, only about 4 ounces of gear oil came out which I found strange. I added about half a liter, or more of 80/90 Valvoline (non synthetic) gear oil until the level came up about 1/4 inch over the bottom of the splasher... just like the builder recommended... even though it wasn't there to begin with. Took it for a ride and now it's spitting gear oil near the drive sprocket. It's enough so that it's getting on the back wheel. I immediately sucked out the gear oil until it was at the very bottom of the splasher, and it's still leaking. Worse yet, now I think I'm hearing a whining noise - or maybe my senses are heightened...
Either way, I'm reluctant to ride the bike until I can figure out what's going on.
Any ideas?
Thanks in advance.
Any ideas?
Thanks in advance.
More than likely main seal is leaking which it why it was so low to start with...you filled it up and it started pouring out..common four speed problem...this page shows how to fix it.
http://shovelhead.us/pics/sheets/leakingtranny.pdf
Any ideas?
Thanks in advance.
Any ideas?
Thanks in advance.
the old glass fuel filter is very cool tractor supply has them in stock if you need a new gasket for it or paper filter BTW -- and + 1 on the it needs an air filter
Oh wow - thanks for all the feedback, and for posting the picture! You're right... it's about 12 hours away, and I already shipped the bike back 2 weeks after I got it last year (for some other repairs) and waited 9 months to get it back.
Either I will take it to a local shop, or attempt this myself. I already found the modified spacer with the o-ring on eBay from saddlebag rail, and the james super nut sprocket seal. From what I've researched, these are the two best fixes. Is there anything else I should be looking for?
Also, the bottom of my tranny is stamped "34703 65" Does this confirm it's a 1965 tranny?
1965 C and D
1966 D,E,F, and G
1967 D and E
1968 E
1969 E and F
1970 F and G
1971 G and H
1972 H,J, and K
1973 K and L
1974 L,M,and N
1975 N,P, and R
1976 R,T,U, and V
1977 V,W,X
1978 Y,Z
1979 Double Letters
1980 Double Letters
Yikes - I'll keep my fingers crossed that isn't the case. After watching too many YouTube videos about how NOT to pull your clutch basket off, I decided to bring it to a professional.
I am in the process of ordering the spacer with the o-ring now, but unfortunately the shipping is more than the spacer, unless I want to wait 10 days!
Canada...
Canada...
