extended forks
extended forks
I have what I perceive to be extended forks on a 74 flh. I have a nacelle and the beer cans are about three inches to short to cover the entire fork tube. I have been told there is pcv tubing in the top of the fork and if I pull the plug and take it out and shorten it, the forks will be back to a proper length. I don't recall seeing anything like that in them when I assembled the bike but then again, I never looked for anything like that. Is this true and if so, is it safe? Any suggestions would be appreciated. I have long fishtails on it and they are about three to four iches off the ground at the back due to the front end beinging that much higher not to mention the kick stand now is short as the bike really leans when its on it.
randy
randy
Received 3,220 Likes
Randy, only parts needed are the tubes. But I would also get the gaskets needed since you will pulling the tubes out of the sliders. Just need to make sure you what year your front end is before ordering the tubes. Once you have it apart you can post pics of the pieces and it will be easy enough to tell if need be.
