82' FXB Sturgis - starter issue
Hey everyone,
I'm having some issues figuring out how this starter mech works. I am fairly sure it is not the stock equipment. So, should the starter shaft fit snugly into the case housing or does it float in there? The reason I am asking this is because I cant seem to get the starter to engage properly. If the shaft is in the case hole (which looks right) it is pushed back out when I try to attach the housing cover. If I leave it that way then the arms on the lever don't travel far enough to properly engage the starter motor. It is as if the shaft is 1/2 inch too long but everyone keeps referring me to part number 31310-80A. This is 7& 1/8 long and the same length I currently have.
I posted a few images at http://www.thebardrinking.com/82FXB/
Any suggestions and thanks in advance!
I couldn't pull up the photo's. The stock shaft fits into a gear in the starting housing. It is held on the outside end by the primary cover bearing. The difference between 31310-80 and 31310-80A is a shoulder where you have a snap ring groove. If you have an 82 you probably already have the newer shaft. Make sure that the splines in the shaft engage the ones in the gear fully and that the shaft is through the bearing and into the seal behind. The shaft remains in the same position during operation and the bendix gear is pulled forward by the shift lever along the worm gear of the starter shaft.
Try to get a service manual and parts manual that covers your model. You can compare it to what you have.
