Eating crank bearings
Old 08-21-2014, 10:10 AM
Daves'81FLHS's Avatar
Daves'81FLHS
Daves'81FLHS is offline
Default Eating crank bearings
1981 FLHS
Got the motor apart and crank bearings and thrust washer shot. Just rebuilt the motor for the same problem. I took the pressure sender off while cylinders are off and attached length of hose with oil in it and added air pressure and the lifters are getting oil but no oil to crank. With cone off did the same to pinion and got oil to the crankshaft. Any ideas.
Thanks,
Dave
Old 08-22-2014, 01:05 AM
FilthyLucre's Avatar
FilthyLucre
FilthyLucre is offline
Did the previous owner replace the cone cover with a pre 73 model. They were side oilers and the post 73 models were end oilers. Put the wrong cover on and no oil to the crank.
Old 08-22-2014, 07:30 AM
johnjzjz's Avatar
johnjzjz
johnjzjz is offline
Received 4,519 Likes on 2,862 Posts
81 has an early and late pinion with different timing on the key to oil hole location - the early goes back to 73 the late into evo to around 87 when they casted the pinion into the flywheels
Old 08-25-2014, 11:07 AM
Daves'81FLHS
They had a older pinion shaft in the flywheel with an older cone cover. Going to replace both with end oiler type. The flywheels are the newer style.
Thanks,
Dave
portlandron
EVO
08-09-2017 03:10 PM
john the hat
Shovelhead
03-05-2017 08:06 AM
1997bagger
EVO
25
10-15-2014 10:13 PM
dmills
Shovelhead
09-16-2010 06:28 PM
Clifton63
Exhaust System Topics
12-06-2007 09:30 PM
Quick Reply: Eating crank bearings
