Cam change gasket set
Old 09-01-2014, 12:00 PM
rsking45's Avatar
rsking45
rsking45 is offline
Default Cam change gasket set
Today I order Andrews 48 cams,S&S adj push rods, new bearings and the Heartland bearing removal/install tool.
Im looking to get the gaskets and o rings necessary to get the job done. Im finding kits that have all gaskets and o rings that one would use if removing rocker boxes. Is the just a kit that has the o rings and cam cover gasket.
I see fuel moto has the complete kit with bearings $60 plus shipping, but wont use alot of the gaskets in the kit.
Thanks
Rich
Old 09-01-2014, 12:03 PM
Juan L's Avatar
Juan L
Juan L is offline
Moderator
Received 20,117 Likes on 10,260 Posts
Why don't you go to the dealership and pick up what you need?
Old 09-01-2014, 12:15 PM
slyedog's Avatar
slyedog
slyedog is offline
^ you will need a clutch spring and primary gasket anyway. Stock spring will likely slip
Old 09-01-2014, 12:33 PM
JustDave13's Avatar
JustDave13
JustDave13 is offline
Received 15,090 Likes on 6,141 Posts
I just picked up that stuff at the dealer for around 80 bucks.
SE clutch spring
Tappet block gaskets
Cam cover gasket
Fluid
3 o'rings and some exhaust gaskets
Old 09-01-2014, 08:04 PM
rsking45's Avatar
rsking45
rsking45 is offline
Thanks fellas
I got looking around Ronnie HD online semantics and figured out there is the cam cover gasket, and 3 o rings that Ill need so yes ill head to the dealer tomorrow and get what I need. The S&S push rods comes with the tappet blocks gasket.
I sent a email to Fuel moto asking for a new map. Im thinking by next weekend Ill have all the goodies to do the swap
Old 09-01-2014, 08:21 PM
deuce_streetbob's Avatar
deuce_streetbob
deuce_streetbob is offline
maybe im not understanding what you need, but S&S has a great cam install kit that you can find on ebay that has the o rings, cam chest gasket and the better bearings for around $40 if i remember correctly. it has all you need without all the extra garbage just to do a cam swap.
Old 09-01-2014, 08:26 PM
QC's Avatar
QC
QC is offline
Received 19,786 Likes on 9,863 Posts
Most of Harley's gaskets are better than the aftermarket ones in my experience.
Old 09-02-2014, 06:24 AM
mattVA's Avatar
mattVA
mattVA is offline
See my post
https://www.hdforums.com/forum/showthread.php?t=740092&page=2&styleid=9
Old 09-02-2014, 10:30 PM
deuce_streetbob
im pretty sure S&S has a handle on gaskets....and for much cheaper.
dajogejr
12-06-2015 09:50 AM
UltraNutZ
11-10-2013 05:30 PM
Sandcrab
Exhaust System Topics
11-27-2012 10:49 AM
SICKBAGGER
04-04-2010 06:32 PM
Tltrump
12-02-2007 09:34 AM
Quick Reply: Cam change gasket set
