Delkron case bottom cover riveted ?
I bought this shovelhead engine which had a Delkron case. I noticed the bottom cover is leaking and it seems to be riveted. If so do I cut them off and hopefully tap the holes. I've read that they're notorious for leaking but these rivets have surprised me. Any suggestions ?
Well no I'm not sure. They look like they might be tamper prove or some thing. They are rounded heads with a center that appears to have been filled with what ever or they are rivets. I was surprised to see this. Bottom line is I'm going to have to pull it some how. Not sure if I can do it in frame or not, other wise I'll have to pull the engine out of the frame
drill a small hole about .050 deep in the side of the button - then sharpen a punch dont over heat it - but heat the button -- put it the sharpened punch in the drilled hole and hit it in a counter clock wise direction - that should brake it loose - my guess its a kicker so on the right side kick it over hold the kicker down and lay the bike over on to the kicker pedal - you will be able to do 1/2 of them that way on the kick stand side
an angle drill with a very good bit will drill the button off the head of the bolts then a vise grip will turn them right out once the cover is removed
if someone has been and it appears they have - the fasteners are going to be tight - the reverse drill bit only works if it catches an edge and causes a snap in the turning, and thats the way it may be bolted, you would have to be dead on - like on a bridgeport so you dont cut the threads side out at the same time
ya know - I wonder if those are not those stupid safety socket head screws with the center post - the torx-head security button screw - these looked "filled" - I have a Delkron motor down on the stand and I cannot believe they could rivet those bottom screws - the rivet would not pull tight - must be some type of button head screw like a security torx
