Cvaria's 2007 883 Standard (XLCN): Consolidated Thread of Nonsense (Working)
Received 2,189 Likes
I'm consolidating all my nonsense into one thread and will only post mods and other rubbish related to this bike here for this point on. there will be no drag bike making or deep engine digging, i'm not in to that stuff. just a bunch of meaningless mods that keep me off the Hookers, booze and drugs.... that's it.
started as...
current sporty status:
RH
RR
LH
FR
Guts
current dyno, will redo:
sounds like:
goes like:
Stuff done:
Alarm install:
hfsm and smart siren install
Keyless Ignition switch (Airframer Mod): [halted... like lowrider method better]
https://www.hdforums.com/forum/sport...l#post14982133
Tach kit install:
Installing Sportster tach kit, i have some ?'s -- http://lmgtfy.com/?q=http%3A%2F%2Fww...e-some-s.htmll hmm...
1200 Conversion:
1200 conversion or just buy a 1200?
Screaming Eagle II:
Exhaust interchanagebility: do road king and other exhaust fit on 07+ XL?
Vance and Hines Grenades noise megaphones:
https://www.hdforums.com/forum/sport...l#post14887777
Shift peg rubbish:
getting the shift off
Chrome Upper Belt Guard:
drag specialties upper belt guard.... poor fit
Battery cover fix:
Battery cover popping open remedy
Loose oil pump fitting detective work:
2007 883 / 1200 sportser: Oil on the bottom of my bike
Oil Cooler 1-up:
Oil Cooler install write up
Oil tank replacement saga:
Chin Fairing:
Xl883(xx) xl1200(xx) sportster front spoiler(chin fairing) kit install instructions
LED lighting:
Led h4?
Battery tender plug discovery:
admission of shame and ignorance
Seafoam!!!!!!!!!!!!!:
seafoaming the sporty?
Crossover pipe replacement:
muffler support has broken... what gives?
Power Vision:
https://www.hdforums.com/forum/sport...sportster.html
Brake Upgrades:
License Plate Relocation:
https://www.hdforums.com/forum/sport...l#post14887797
Tire Rubbish:
https://www.hdforums.com/forum/sport...re-to-buy.html
2016.5+ Roadster Wheels:
https://www.hdforums.com/forum/sport...wheel-p-n.html
DIY Air Cleaner Vent:
https://www.hdforums.com/forum/sport...l#post15958046
Stage 4 saga....:
started as...
RH
RR
LH
FR
Guts
goes like:
Stuff done:
Alarm install:
Tach kit install:
1200 Conversion:
Screaming Eagle II:
Shift peg rubbish:
Battery cover fix:
Oil Cooler 1-up:
Chin Fairing:
LED lighting:
Led h4?
Power Vision:
Brake Upgrades:
- getting it wrong: https://www.hdforums.com/forum/sport...c-sliders.html
- getting it done: https://www.hdforums.com/forum/sport...l#post14761022
- update- contoured rotors: https://www.hdforums.com/forum/sport...l#post15879387
Tire Rubbish:
Stage 4 saga....:
https://www.hdforums.com/forum/sport...l#post15908773
continues in failure and stupidity for 30+ pages.
parts used:
parts used:
S E PRO CNC PORTED Heads p/n: 16500074
2 x Cylinder PISTON KIT, BLK NO HIGHLIGHTS p/n: 16469-10
S E PRO XL1200 Hi Comp Pistons p/n: 22711-04A
S E PRO Hi Output Cam p/n: 25740-05 (se-575)
S&S quickee pushrods p/n: 30-0023
S&S high performance tappers/lifters p/n: 33-5350
Energy One clutch pack p/n: Btx-11
ENERGY ONE Clutch Spring Compressor Tool
cometic gaskets
cometic gaskets
- Primary gasket set C9125
- rocker box set p/n: C9195
- cam cover gasket p/n: C9944F1
- Cylinder Base Gasket - .020in. p/n: C9214
- Cylinder head gasket - .040 p/n: C9689
- questions about cams: https://www.hdforums.com/forum/sport...r-tappets.html
- questions about pistons: https://www.hdforums.com/forum/sport...d-s-vs-se.html
- questions about honing: https://www.hdforums.com/forum/sport...or-tricks.html
- questions about springs: https://www.hdforums.com/forum/sport...-and-such.html
Big Brake Kit and Brake overhaul
I liked the Ness Big Brake kit on my wide glide. i decided to use one to overhaul, along with front and rear steel lines and a new rear rotor, my sporty brakes. front first
https://www.hdforums.com/forum/dyna-...l#post14741026
Going out for center star powder coating tomorrow:
Goodridge Stainless front brake line is shipping from Amazon:
Lydell Z pads are shipping from Eastern Performance:
http://www.easternperformance.com/ly...harley-xl.html
will stop by the dealer tomorrow and get new rotor bolts
Update: Pads in hand and rotor is out for powder
Dheez (09-26-2017)
Installed ss line, lyndell z pads, and ness big brake kit 02-966
http://www.arlenness.com/prodcat/02-969.asp
got back powder coated rotor. install began
mounted ness brackett
filed down raised portion on boss per the ness instructions. used dremel
http://www.arlenness.com/images/I_02_966.pdf
rotor mounted
used spare gates tubing from oil cooler to protect SS line in clamps
no pretty
done
rotor mounted
no pretty
done
i just took it out to test. there's more bite but i don't know if it's the line or pads, but the days of saggy stop are over. should have done this overhaul long ago.
Having owned Harleys a long time I've tried various things. Aftermarket brake pads can add a little improvement, but I particularly like braided lines. Add the increased leverage your larger diameter rotor provides and you have three separate improvements!
more junk for disk job
new RH ness rotor appeared, will be going out for powder with the rear pulley (and sliders if the are too far apart in finish) next week
stopped by the dealer and coughed up the cash for fork rebuild kits
compared new RH bracket to old LH. good to go.
