Lazarus Project: 2012
Old 07-17-2016, 08:11 AM
cvaria's Avatar
cvaria
cvaria is offline
Received 2,189 Likes on 1,677 Posts
Default 2012 Wide Glide: Lazarus Project- Rebuilding the 2013 FXDWG"1/2 L"backyard mechanic edition
I'm consolidating my nonsense into one thread-and from here on out only posting upgrades and bs in this thread. " 'cos I'm ****ing stupid"
I'm rebuilding the once great 2013 FXDWG"1/2 L"backyard mechanic edition:
https://www.hdforums.com/forum/dyna-...solidated.html
Started as:
Current Status:
current dyno, MAY redo- again:
sounds like:
Goes like:
Impetus:
https://www.hdforums.com/forum/dyna-...l#post15294030
Bike Appears:
https://www.hdforums.com/forum/dyna-...l#post15389840
Issues:
stuff did'd-----------
LCD Temp Gauge:
https://www.hdforums.com/forum/dyna-...l#post15566291
USB/ new battery/ pigtail for tender:
https://www.hdforums.com/forum/dyna-...l#post15394523
DK 2" tank lift and ball mount:
https://www.hdforums.com/forum/dyna-...l#post15400959
black console:
https://www.hdforums.com/forum/dyna-...l#post15408454
Exhaust:
Arlen Ness Big Sucker:
https://www.hdforums.com/forum/dyna-...l#post15410319
Air cleaner trim from pop's garage:
https://www.hdforums.com/forum/dyna-...l#post15877218
Performance Machine Horn cover:
https://www.hdforums.com/forum/dyna-...l#post15522419
Jagg fan assisted Oil Cooler:
https://www.hdforums.com/forum/dyna-...l#post15413168
primary cover swap - chrome to wrinkle black:
https://www.hdforums.com/forum/dyna-...l#post15418638
Cushion foot pegs install:
https://www.hdforums.com/forum/dyna-...l#post15421562
Pedal pegs:
1. https://www.hdforums.com/forum/dyna-...l#post15566291
2. https://www.hdforums.com/forum/dyna-...l#post15567664
3. https://www.hdforums.com/forum/dyna-...l#post15575021
4. https://www.hdforums.com/forum/dyna-...l#post15576202
5. https://www.hdforums.com/forum/dyna-...l#post15577129
Cushion Kustom Khrome Grips:
https://www.hdforums.com/forum/dyna-...l#post15424096
3" Riser Exstentions and solid bushings:
1. https://www.hdforums.com/forum/dyna-...l#post15471519
2. https://www.hdforums.com/forum/dyna-...l#post15472361
3. https://www.hdforums.com/forum/dyna-...l#post15478996
Colorado Customs Cyko Wheels:
1. https://www.hdforums.com/forum/dyna-...l#post15592714
*various failures and nonsense*
2. https://www.hdforums.com/forum/dyna-...l#post15598463
3. https://www.hdforums.com/forum/dyna-...l#post15701119
Brakes:110 engine upgrade:
used:
S&S 110 winter power package
rockers
  • box gasket set C9588
  • new breathers (17025-03A)
  • rockout rocker shaft inserts
primary
  • Cometic Gasket Derby Cover Gasket - 5-Hole C9997F1
  • beat-up figure machine clear derby cover
  • SE clutch diaphragm spring 37951-98
  • AIM variable pressure clutch VP95TL
  • Cometic Gasket Cometic Primary Gasket AFM C9145F1 0934-1205
  • Barnett 307-30-10013 Extra Plate Clutch Kit Kevlar
Goodridge 1/4" MCD04V In Line Metal Fuel Hose Quick Release Disconnect Coupling for crossover
after getting premium info from the folks in the engine etc forum:
A: things to look out for while checking my run out
https://www.hdforums.com/forum/engin...y-run-out.html
B: cam bearing installer/puller recommendations?
https://www.hdforums.com/forum/engin...endations.html
C: beefing up the clutch
https://www.hdforums.com/forum/dyna-...he-clutch.html
S&S 110 winter power package ordered:
1. https://www.hdforums.com/forum/dyna-...l#post16170889
2. https://www.hdforums.com/forum/dyna-...l#post16181498
work starts:
https://www.hdforums.com/forum/dyna-...l#post16266349
Dheez (02-01-2018)
Top Answer
07-07-2018, 04:20 PM
cvaria's Avatar
cvaria
cvaria is offline
Originally Posted by Reindeer
Not a lot of info, but at least it's something relatively positive. Thanks for keeping us posted.
I suppose to his family their least concern is updating forum members, which is understandable especially if he's in rough shape.
THNKS ALL FOR THE WISHWSES. RHERE WERTE QW NUMBWR OF INCIDENDENDS FOR ME... I THREW IF THE THIS SET OF INCIDENTS THOUOH... BEEN ROUGH. REHAB LOST MONEY. FAMILY STEPPED UP[ MAJORLY... NEED FOR SPEED WILL BW ME WITH MY GOODNESSS....4 WHEELS... LUCK YTO BE ALIVE OVR HERE..... ELIMINATING ALLL BIKWS UIN MY INVENORY
Old 07-17-2016, 08:17 AM
TinCupChalice's Avatar
TinCupChalice
TinCupChalice is offline
Received 8,749 Likes on 3,962 Posts
IN
This is going to be fun to watch!
TinCupChalice
EDIT: It double posted, even the Dyna forum is excited!
Old 07-17-2016, 09:46 AM
Mchad's Avatar
Mchad
Mchad is offline
Received 3,507 Likes on 2,132 Posts
Can't wait to see!
Old 07-17-2016, 10:37 AM
Maxxsmart's Avatar
Maxxsmart
Maxxsmart is offline
Looking forward to this one!
Old 07-17-2016, 09:22 PM
cvaria's Avatar
cvaria
cvaria is offline
Default Crusty Eagle II's Aquired
yes, i could get better pipes but, i like that these vanish at highway speeds yet bark around town. need more stock street bob headers... anyone have some haunting their garage?
Tazze (10-26-2020)
Old 07-19-2016, 10:50 AM
Reindeer's Avatar
Reindeer
Reindeer is offline
I've got a set of stock Super Glide headers, which are the same as Street Bob. They're off an '09 though, which I believe have different sized O2 sensor bungs than a '12. Shoot me a PM if you want 'em.
cvaria (07-19-2016)
Old 07-19-2016, 11:44 AM
mattVA's Avatar
mattVA
mattVA is offline
I have a pair of late model street bob headers that have been haunting my garage. They have the 12mm size O2 bungs.
cvaria (07-19-2016)
Old 07-19-2016, 11:46 AM
cvaria's Avatar
cvaria
cvaria is offline
thanks, i'm looking. i used 2010 street bob headers last time and they have the same o2 sensor listed (27683-07). so i might be able to get away with it. the part numbers are different for the headers though. yours are 65440-06 & 65631-06 vs the 10 bob's 65631-10 & 65825-10. something changed not sure what. doi you have the shields or are you using them currently?
Old 07-19-2016, 11:47 AM
TinCupChalice
You're exactly right; the size of the O2 sensor bung was changed from 18mm to 12mm in '12 across the Dyna line. cvaria can pick up some 18mm to 12mm bung adapters rather inexpensively which would let him use the exhaust from your '09...
cvaria (07-19-2016)
Quick Reply: Lazarus Project: 2012
