Bigger injectors=new tune?
Old 09-23-2016, 12:38 PM
hd_rolling's Avatar
hd_rolling
hd_rolling is offline
Default Bigger injectors=new tune?
I believe I'm at the max or over the amount my 5.3 injectors can handle, and I'm bored.
So I have a new set of SE 6.2 injectors on the shelf, just wondering if I can slap them in and the target tune module will auto tune to compensate for the bigger flow or if I need to request a new tune from Fuel Moto?
I'm thinking of going to a 124 upgrade kit this winter and want to get into the 140 range, so the bigger injectors are just in preparation of things to come.
New tune or just install and run them?
Old 09-23-2016, 01:14 PM
Next In Line's Avatar
Next In Line
Next In Line is offline
Unless you are running full throttle 100% of the time through all the gears, it is very unlikely you are maxing out the 5.3 injectors.
You will need a new map if you change the injectors due to the difference in flow rates.
Old 09-23-2016, 01:28 PM
qtrracer's Avatar
qtrracer
qtrracer is offline
I am also not sure you are near the limit of what the 5.3's can do.
Old 09-23-2016, 01:30 PM
soft 02's Avatar
soft 02
soft 02 is offline
Running 5.3's in mine. Work just fine.
Old 09-23-2016, 02:03 PM
qtrracer's Avatar
qtrracer
qtrracer is offline
I put in 160hp desired at 85% duty and 55lb fuel pressure and it comes up 42lb which is 5.3grams/sec. So I think the 5.3's will be fine
Old 09-23-2016, 02:23 PM
ramx50's Avatar
ramx50
ramx50 is offline
Same for me, I was running the stock 120R injectors in my Procharged setup with 218hp to the tire.
I only had to upgrade my injectors and fuel pump for my current setup @242hp.
Old 09-23-2016, 02:41 PM
hrdtail78's Avatar
hrdtail78
hrdtail78 is offline
What are the 120R stock injector size?
Old 09-23-2016, 03:05 PM
ramx50's Avatar
ramx50
ramx50 is offline
5.3
grams/second in a 58mm throttle body.
Old 09-23-2016, 03:22 PM
hd_rolling's Avatar
hd_rolling
The 120R doesn't include injectors or throttle body, so when you buy the engine you also have to pick up those items.
I've always read the 5.3 were only good for the 120 hp range, and after that you were over working them.
Like I said I was bored and ordering stuff anyways and just added these to the cart as well, maybe I'll install them at the same time I do the 124 upgrade and only have to worry about getting one new map.
Thanks for the replies.
Old 09-23-2016, 03:26 PM
qtrracer's Avatar
qtrracer
qtrracer is offline
Whom ever wrote that 5.3's were only good for 120hp was incorrect for whatever reason. I'm using 5.3's and I'm way past 120hp. 5.3's are good to at least 160hp@55psi and at 85% duty cycle.
Quick Reply: Bigger injectors=new tune?
