Fork Aluminum Oxidation
Location: Depends on who wants to know.........and why.
Received 1,901 Likes
All good tips. I did mine two seasons ago when I had to replace the seals. Did a total disassembly but not necessary. My 94 dyna had the original clear coat and it was looking nasty.
I used paint stripper to get the old clear coat off, then did like what others mentioned using various grits of wet sand paper. My goal was to keep the original "brushed" look but I did not want to re-clear it.
Using the wet sandpaper to get the nasty stuff off like 220, then went over it 400/600. Can't remember if I went any finer but was not to worried because of the finish I was going after. If your gonna polish them then go finer. I used the green 3m scotch brite and "grained" it (for lack of a better term) by wrapping the pad around the fork and twisting while paying attention to pattern or grain.
It turned out really well, and I just wax the aluminum 2 or 3 times a year when I wax the bike and it seems to be holding up well (bike is kept in garage). If it does get funky, I can touch it up with the scotch brite.
The clear from the factory and any clear that you put back on is only going to chip, peel, and yellow over time. So leaving the clear coat off with either the factory brushed look or with polish will make easier to keep it looking good. I did this with my sporty years ago on the forks, primary and valve covers and could not be happier with it. YD
