Installing USED gear drive cams
Old 09-27-2016, 11:36 PM
Road Star's Avatar
Road Star
Road Star is offline
Default Installing USED gear drive cams
I have a set of used Andrews 37G cams, along with a new install and gear kit.
The cams look real good, no signs of any wear. You guys think it would be ok to use my old lifters? The bike has 50K miles. If I pull the old lifters and they look excessively worn, I will change them. Just wondering if using the old lifters with a used cam would be acceptable.
Old 09-28-2016, 01:41 AM
Road Star's Avatar
Road Star
Wow, didn't realize lifters were that cheap. Guess it's new lifters.
However, getting the bearings on the cams and getting them in the cam plate is another story. Is the freezer-cams/oven-bearing the best way to go? Putting the bearings or the cam plate in the oven won't cause any damage?
Old 09-28-2016, 12:41 PM
lt1-xjs's Avatar
lt1-xjs
lt1-xjs is offline
If you don't have the correct tools, take your plate, bearings, cams, etc. to a dealer and have them do it for you. They shouldn't charge that much.
Old 09-28-2016, 12:48 PM
QC's Avatar
QC
QC is offline
Received 19,786 Likes on 9,863 Posts
Agreed, take it to a place that can press them correctly. Although the freeze and heat method will work.
Old 09-28-2016, 01:15 PM
ORradtech's Avatar
ORradtech
ORradtech is offline
Agreed, heat/freeze does work but it's really never as easy as people would have you believe.
Old 09-28-2016, 02:27 PM
grbrown's Avatar
grbrown
grbrown is offline
Red face
Each of us has a different threshold when it comes to doing what I will call the more difficult jobs. That is one I would prefer to have done by an expert!
Old 09-28-2016, 02:44 PM
Road Star's Avatar
Road Star
I agree, however, having not worked with a particular shop, how would you know their expertise? They could turn out to be dumb-asses.
Old 09-28-2016, 02:58 PM
grbrown's Avatar
grbrown
grbrown is offline
Wink
I would only chose a shop with a decent reputation, it's as simple as that! Fortunately I have a local indy who is a long-standing H-D Master Tech with an excellent reputation, who has done a lot of work for me over the years. Find an owner you trust who can make a similar recommendation.
Old 09-28-2016, 03:03 PM
Joe12RK's Avatar
Joe12RK
Joe12RK is offline
Received 1,410 Likes on 880 Posts
the tools will probably cost as much as having a dealer do the job, and you'll have to tools and experience when you are done
Old 09-28-2016, 03:11 PM
Uncle Peepers's Avatar
Uncle Peepers
Uncle Peepers is online now
I installed a set of used Andrews 37 G cams in a 2000 FLHTCI using the over/freezer method. It was the first time I'd undertaken anything like that. It worked fine and was kind of fun.
Quick Reply: Installing USED gear drive cams
