Oil issues remain
Oil issues remain
So had my bike in the shop for over 5 months due to oil building up and dumping out of the rear breather. The top end was sent back to Zipper's Performance so they could investigate the problem and come up with a solution. Well I got the bike back from the shop with newly honed cylinders and new pistons along with other modifications to fix the issue and increase the performance at high altitude operation for where I live.
Once the engine break in period was complete I opened it up to see what she has and to my dismay, oil dumped out of the rear breather again just as before. It dumped all over the side of the engine case ans on the exhaust. The same issue remains even after dozens of tests performed by Zipper's to find the cause of the issue and fix it. They thought they had solved the problem but it turns out they did not.
What do I do now? What would you guys do? This kit has been back to Zipper's 2 times now and has been torn down by the shop 3 times to fix issues. I am at my wits end here! I have had nothing but problems with this kit from the start and they continue to exist.
Received 2,189 Likes
drinktothat421 (10-20-2016)
I believe you had two threads on this saga and I read both.
This being a third thread I recall a few months ago the issue was solved.
Maybe as referred to above....best option...return to stock...get refund...buy another bike.
(Since no one can find something obvious...maybe it is somewhat unobvious, such as a cracked head, casting etc. Yet the pros are failing to find it.)
So maybe cut your losses and move on is best for your quality of life.
Good luck. Just a terrible story, yet many have similar stories when modifying motors (cars and bikes) so you are not alone.
Haha at this point I may have to sell my house just to be able to fix the bike. Im not sure that the altitude has much if anything to do with the oil being forced out of the rear breather but I don't know. All I do know is that this is a nightmare that won't go away!
Received 3,930 Likes
Man, I am sorry to read what you are going thru.
I followed your thread from months ago...then had not read anything and thought you must have had it straightened out.
I concur, partially, with cvaria. Have Zippers pay to have it put back to stock. Get your $ back for their kit that they can't make work. Then decide if you want to sell the bike and start fresh with another bike, or start over with that bike, with a more proven upgrade.
I know you'll still be out $ and a ton of frustration, but it seems never-ending...seems better to start fresh.
I just want my bike to ve enjoyable again. I guess that's why they say if it aint broke don't fix it. I learned that lesson the very hard and expensive way that's for sure.
Of course the dealership that did the work is more than willing to trade me onto another bike but I just cant afford to have another payment and I know they won't give me crap in trade value on my 48. Im kinda stuck here if Zipper's refuses to fix it or return it back to stock and refund the kit.
