Will 2014 stock exhaust fit a 2009?
according to the V&H site it doesn't appear that a 2014 exhaust will fit a 2009.
I'm not sure if the reason is the difference in motors or how they are mounted.
Any way just in case anyone wanted to know my reason for the question.
The short shot staggards are just a bit loud for long rides and I was thinking perhaps putting on a set of stock pipes would make the long ride more pleasurable.
We only take a couple of long rides/trips a year so it wouldn't be that big of a PITA to swap pipes just for those two occasions.
My bike didn't come with stock pipes and I found a new 2014 set for $40 hence the reason for the question.
Should be able to purchase reducers for to O2 sensors if that is all that is holding you back. I had purchased V&H pipes for my bike and bought the wrong ones which was for an older model bike but the only difference was the O2 sensor size so I purchased reducers and everything worked fine.
LMFAO, but man we were using newer technology then than harley did in 2009 and 2013 hahahaha.
It's very possible, just need some 18mm bungs and a dude than can weld exhaust because to my knowledge mounting locations are still the same. I could be wrong there but I am pretty sure the bung size is the only difference between any twin cam models. So the 13 exhaust should fit with about 30 minutes work from a decent welder.
