B2112 - Accessory Output Shorted High
Per the 2014 Electrical Diagnostic Manual:
B2112 - ACC output shorted high
Conditions for Setting
The accessory circuit normally has power when the IGN is ON or in the ACC positions. If the accessory circuit has power when the IGN is OFF, then the BTC B2112 will set.
DTC B2114 will set if the accessory circuit draws more than 20 Amps.
The other accessory circuit DTCs will set if the BCM identifies them with the IGN ON or in the ACC position.
Diagnostic Tips
This circuit may be used for aftermarket accessories or systems. If a code is set and cannot be duplicated, check for aftermarket devices.
Possible Causes
Short to battery in the accessory power circuit.
1. Accessory Power Circuit Short to Voltage Test
No. Go to Test 2.
2. BCM Test
No. Concern is intermittent. Accessory devices may have caused DTC to set. Inspect & repair as needed.
Good luck!
Diagnostic Tips
Possible Causes
- Turn IGN OFF.
- Using HARNESS CONNECTOR TEST KIT (Part No. HD-41404), test voltage between DLC [91A] terminal 5 and ground.
- Is battery voltage present?
No. Go to Test 2.
2. BCM Test
- Clear DTC.
- Turn IGN ON-OFF>
- Check for DTCs.
- Did DTC return?
Good luck!
tgmotoman (08-12-2018)
