Power Vision Tuning Control Question
A few days ago, I replaced the PowerCommander3 that was on the bike when I bought it, with the Power Vision. Very nice unit and easy to use. I don't own a Windows based computer, so the stand alone "dash" was one of the selling points.
The map that was supplied to suit my combo was good enough to get my '06 Deluxe running after a cam change, but not running near well enough. Intermittent missing while under light throttle at low speeds, running a bit too hot, decel popping, and white plugs.
So, I've been using the "Fuel" tab in quick tune to give it more fuel. I've given it. A bit more fuel in increments in the "low" and "med" areas. Each time I add fuel it makes an improvement.
I've been wrenching a long time, but I haven't done anything with EFI tuners. I read some about using the VE tab, but how does that relate to using the fuel tab? Would it better to use that than it would the fuel tab to make fuel adjustments?
Call Fuel Moto and explain what's happening (sounds lean). Send them the map you are working with and they will send a new map in short order. They are very good about taking care of issues like yours...and will continue to work with you until everything is resolved.
Thanks. I'll have to call 'em today. I sent an e-mail yesterday morning, but have not gotten a reply yet.
As it turns out, simply adding fuel was not the answer. The intermittent miss was still there, and it was running very rich and getting really crappy fuel mileage. Just to satisfy my own OCD tendencies about this kind of stuff, I returned the bike to the stock tune, and plugged the PC3 back in. Runs good again, just a touch lean. This confirmed in my own mind that there is nothing wrong with any of the bike's systems.
I was so hoping to rid the bike of the piggy-back tuner, so I hope that this can be resolved.
Just got off the phone with Jamie at Fuel Moto. I honestly don't know what I expected him to do, but right now, I'm regretting my decision to buy the Power Vision. The purchase was based on "No Computer Needed." I don't own a windows based PC. To get and load a different tune into the PV, I either need to buy one or borrow one. Either more money spent, or going against one of my personal credo's....Neither Borrower nor Lender be. I know I certainly wouldn't lend my PC to anyone.
Another option is I can send the unit back after filling out the forms they have on their website and have them reload a tune or two.
He also mentioned getting it dyno tuned. Probably what I should have done initially, as that could have been done without buying the PV and the cost would have been close to the same as buying the PV and I would have been done with it.
Can't sell the dang PV, as now it's married to my bike.
Regardless, it's gonna be a bit of a pain to deal with, although I'm sure it will work out in the long run.
It's a good thing it's winter!
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
Hey Mike...
Don't know what you discussed with Jamie, but he's definitely the expert you want to be talking to. If you haven't discussed VE's and other conceptual things with him, I can give you my answer to your question....
I like to simplify things... So I like to think of the Volumetric Efficiency (VE) tables as your tune's model for Air in the Air to Fuel ratio calculation. Definition wise VE is:
That definition and more information came from here:
https://en.wikipedia.org/wiki/Volumetric_efficiency
The VE tables are where you make enrichment and enleanment adjustments. If you want to address a lean spot in your tune (performance band/area of operation), then you increase the VE number in that spot in the VE table. The result of that increase tells the ECM that it has more air coming in at that spot and therefore it needs to apply more fuel to meet the set AFR in the corresponding spot in the set AFR table. Same thing goes in the opposite direction. For a rich spot you reduce the VE number to lean it out.
Volumetric efficiency (VE) in an internal combustion engine design refers to the efficiency with which the engine can move the charge of fuel and air into and out of the cylinders. Volumetric efficiency is also ratio of mass of air drawn in cylinder to its swept volume. [1] More specifically, volumetric efficiency is a ratio (or percentage) of the mass quantity of air and fuel that is trapped by the cylinder during induction divided by the mass that would occupy the displaced volume at the density of the air in the intake manifold...
