Ebay high torque starters
looking on ebay they range from 150 to 300 1.4kw to 2.4kw no name brands, pro torque, all b**ls, too many to chose from. My autozone battery didnt last a season (I know ya get what ya pay for) but i figured a high torque starter would not beat up the battery so bad.
Advice appreciated, id like a season of riding this year without jumping the thing first
http://www.ebay.com/itm/89-06-HARLEY...FV9wYt&vxp=mtr
Received 4,317 Likes
My last one lasted over 4 years and still turned the bike over fine but voltmeter said it was starting to get weak.
Received 14,135 Likes
Pretty much any 1.4 Starter will get you there. The battery should be at least 270 cca and cables are not really necessary unless you have too much voltage drop across the cable. I bought a no name 1.4 kw six years ago matched to a high compression motor and it's still ticking. You really don't need anything greater than a 1.4..... If your running 10.0:1 or higher you should consider compression releases...
Not cheap, but spins the 111 over like a toy, never have to charge it, but it does use a standard charger if need be.
I have better cables and Allballs 1.4k also.
http://earthxbatteries.com/shop/etx36c
Depending on what year your bike was manufactured makes difference in starters. I know my 98 originally came with a .8kw starter and when the 88"er's can our they stepped it up Rio a 1.2 kw starter. So yea your 96"er probably had a slight studder initially at 10.0:1 but if you use a .8kw it'll sound like a capacitor...
