Question on the DD AW 6.5 w/tweeter setups
Glad to see that the reviews coming in so far are very positive for the initial installs (not that I expected anything less).
I'm running BT 4180 amp and would prefer to keep that instead of selling it and buying a DD or 600.4.
So here's my question: How much of the success of these setups is based on the ability to tweak the amp gains to get the best sound? Since I wouldn't have the option to do that, how much would I be leaving on the table with the component set up?
I realize it's hard to quantify that, just looking for a level of magnitude here - not enough to make a noticeable difference, less than ideal but still significantly better than non-component speaks such as the 602s or BT 6.5, or huge difference that it's not worth doing with that amp.
Thanks in advance guys and ride safe.
Be patient. A few guys are installing them with BT4180 as we speak. As out resident expert, Slye, indicated I don think power will be a concern as I'm a running less W than u have.
I think the recommended crossover is around 80-90 and think the LL is crossed around 80 (not certain of that) but I predict that amp will do just fine.
We will know soon enough. Worst case, Mike at BT would be more than willing to assist with any fine tuning of the LL.
T
T
T
T
Have you heard anything from the guys who were installing these with the 4180? Any vids? Haze found the treasure with these speaks. They are amazing and I'm anxious to hear them running on that amp!
- FW
FW - to be very honest all credit goes to T for treasure hunting and finding the AW's. We were looking for a speaker that could play low enough and high enough when he said hey check the specs on these. So props to T!
With regard to the 4180.....brutha, you are NOT going to hear a bad review man. There's a vid and review posted using an Arc 600.4 and one with the JL bridge to 140w. This is very close in power and sound to the 4180, what you heard from them will be very similar. Don't think anyone's gonna post they're not happy. I know a few guys who got them and were using that amp. Not one bad email yet!
Hey BTW, I got a chance to put my headphones in and listen to the black glide you did (I feel blessed) with 6 speakers and 2 horns. Geeez Louise that thing pounds and it's clear as a bell. Were those VO horns?
-FW
Those were Hertz horns. Very comparable.
The thing with the 4180 and the crossover is most guys have been crossing their amp at 80-90 hz which is pretty high and still get good bass from them. I really think what rapes the lows the most is the LL. If you really want awesome sound you need a micro DSP in your fairing. Those are coming soon too!
I'm having to set the bass to maximum and the treble to minimum, otherwise the tweeters are too bright. This doesn't seem normal, but then again, this is my first Rushmore.
Is this normal?
Are there any adjustments that can be made to the BT355? (It's set a default)
Will a DSP allow me to take some of the brightness out of the tweeters?
